2006 S60 2.5T with 162,000 miles, am having the passenger side inner/outer tie rods replaced since there is some play in them. The struts were replaced previously; otherwise, the suspension is all original. I plan to keep the car for at least another 3 years; trying to keep the car as stock as possible. Anything else I should ask them to do while they are up in there?
There's not much to getting to the tie rods. Therefore not a great time for "while you're in there stuff." except for maybe the sway bar end links but I'd only replace them if they are making noise.
With that mileage,I would be shocked if the control arm bushings are still good.Probably a good time to replace the end links too.
