So I’m at a loss.. I’ve basically replaced everything in the front end and I’m still getting a clunk. It’s almost like a knocking noise, I’ve replaced the end links with Whiteline KLC 151s, both strut mounts and bearings and the right side control arm.. all the mounts and I’m still getting a clunk. Could this be the bushings gone on the sway bar?
I have heard that this is a fairly common failure, the sway bar bushings
2007 V70R Ti Grey Nordkap GT, 2008 C30R-Design Black M66
The passenger side Engine mount is almost certainly toast!!! You can also replace the lower mount as well while you are at it! Go with the Ford E-Focus mount. Every passenger side mount I have seen with some miles on it, was falling apart.
