1 - 1 of 1 Posts
Hi
So my sunroof before would not stay in the close position. Closing the sunroof from vent to close or open to close would just take it from vent to open; vice versa. Thinking that it was the switch, I finally got around to replacing it nearly a year later. Now, the sunroof is stuck open in the vent position when I went to test it. It will not close or go back in the opposite direction. I can hear a click when I press the vent position, but nothing in the open/close position. Is there a manual override to crank it close? Or is that only for 850s? And if not, can I take off the motor and close the sunroof manually?
Also, what is the likely part malfunctioning? Motor or control module?
Thanks!
1 - 1 of 1 Posts
