Update, I removed the overhead console panel buy simply pulling it down since it's held in with clips. The drive motor for the glass is on the right hand side of the hole. With some difficulty and small tools I was able to get to the motor, inset a small hex and manually close the sunroof by advancing the motor manually.
After this I reconnected the overhead console and everything came to life. Using my Autel scanner, I ran the sunroof calibration routine and it reset the roof and the sunshade. Everything is working fine now but I still don't know the root cause for the issue. Cleared all codes and back in action.
Hope that helps someone else.
