· Registered
I tried to close my sunroof after installing my CD changer, sunroof has no power. Neither does the garage door opener or the interior reading lights. I checked the fuses and all look intact, am I missing something!?! I didnt cut any wiring harnesses or even move them, I have no clue to whats going on, any help would be great!
· Registered
Re: Sunroof failure w/ CD changer install (snowdragon3)
Assuming you disconnected the battery while installing the CD changer, functions should return after a few (3-5?) on-off cycles. I've had similar issues after a battery disconnect.
· Registered
Re: Sunroof failure w/ CD changer install (hastee)
when the battery is disconnected, the electronics systems need to reinitialize in the proper sequence. Apperently, they don't when we just connect the power.
Just lock/unlock the door (I think have to use the switch in the car rather than the remote, not sure) then everything resets properly. I randomly found this solution and got a confirmation from a Volvo tech.
