The sunroof likes to open but not close. <p>I think it is the switch as the motor (when it works) sounds ok. I was able to close it recently only by playing around with the connectors on the back of the switch (the Red and Yellow striped wires to be precise).<p>Does this sound right? THanks in advance, jeff
Re: Sunroof Acting Up - Switch? (jflowers1974)
Ive had some similar problems with the sunroof on my 940 dying on me. If it ever gets stuck open and you cant get it closed, pop the dome light cover off and you can see a little screw you can turn to manually close the sunroof. But if its the switch, all you may need to do is reattatch the ends of the wires to the switch with a soldering iron.
Had the exact same thing happen on my 940. It happened to be the switch. Get yourself a new one from fcpgroton or your favourite online shop. Dont buy from a junkyard because in another year or two that too will go down the drain.
