This all started when the EVOLVE springs were installed!!!!
Quote, originally posted by SilverSurf"R" » |
This all started when the EVOLVE springs were installed!!!! |
Does any one know what the correct voltage feedback is supposed to be? |
SilverSurf"R" We can raise and lower the body on the car and the voltage feedback changes. Raising cause the right to go down and the left to go up said:If you are raising ONE side of the vehicle, and thusly making the other side go down, than this is the correct behavior. If you are suggesting that the rear of the car is being raised as a unit, than you should see both values change about the same amount, in the same direction. (Can a real tech validate this, since I have not validated this on my own car)
You want to have the position sensors at their midpoint of travel when the car is at rest in it's normal static position.
Quote, originally posted by Oceans60R » |
After looking at a wiring diagram it appears that your right rear level sensor is possibly installed upside down. Should read .5v fully loaded or compressed and 4.5v unload. Your RR is reading opposite. So I would check that sensor and verify its installed correctly. Maybe it was removed or something during installation. |
