This week the car suddenly began smelling musty. Thinking maybe a clogged drain? Going to deep clean the interior, but I can't locate the source. Any suggestions?
Are there any drains I can check for the sunroof? We did have a few bad days of rain.Dead mouse?
Play detective and check around the car for anything that could be causing the odor. Look in pockets, under seats, on floor mats and even in the glove compartment for baby bottles in the back seat, moldy fruit in forgotten bags or unidentified blobs that may have been dragged in on the bottom of someone's shoe. Immediately remove and throw any of these away and open the doors for a while to let any lingering odor dissipate. Don't forget that sometimes a funky smell can also be a sign of an overheated car - or you may be in need of an oil change.
If you can't find the source, pull out the car vacuum. Many times the upholstery, carpet or fabric interior can trap odors. Work the vacuum all around and down into crevices using the upholstery attachment. If this doesn't do the trick but you believe this is the source of your odor issue, try steam cleaning where possible. If you have leather seats, you can clean them thoroughly
Mildew is another source of unwelcome odors. All you need is one rainstorm and an overlooked partially opened window (or even just a small leak with a buildup of condensation), to experience this. Luckily, removing mildew smells in cars is pretty straightforward. A wet/dry vacuum can help remove remaining water from carpets and upholstery but, in a pinch, even a hair dryer may work. If a small leak is the cause, you may have to hunt around a bit. Check under the mats as well as in the trunk for any condensation, including checking the area where your spare tire is stored.
One other possible source of that mildew smell is the air conditioning system. One telltale sign is damp floor mats near the air conditioner. If you find an odor coming from this area, open the front cover and remove the filter. Use a nylon scrub pad to remove any mold growth, then use a cotton swab to dry it. (To finish drying things out, turn on the car's heater.) When you're sure the area is completely dry, apply an anti-mildew solution, enzyme cleaner or odor absorber. You could also sprinkle baking soda on the upholstery and leave it in place for a day or so before vacuuming away. By then, the smell should have dissipated. You also may, of course, remove any car mats and let them air out for a while.
After finding the source of car odors and treating them, your car should smell great. With the help of a new car smell air freshener, could almost smell as good as new.
