Re: Subwoofer for the S60 R (Short Circuit)
REEEAAAALLL easy. I dunno for your app, but on my S60, there was a fuse block in the trunk on the left side, behind a panel. Take that panel off and use a multimeter to find out which junction block is switched 12 volt. Once you find that, just run an 18 GA wire from that to the remote line on your amp. For RCA's I use a Low-Level Converter for now, which I got from Circuit City, that runs off of the back speakers, and convieniently those wires are in the trunk too, just look up when looking in the trunk. There is a way to get the factory deck to run an amp, depending on the deck you have, which has 4 channel pre-outs with remote line output also. I dunno if this will work with the S60, I think it will, but I'm gonna try it soon when the weather gets better and yes, I will take pics. Here's the link for the deck pre-outs.<br><A HREF="http://project850.volvospeed.com/installguides/RCApreout/RCA-preouts.htm" TARGET="_blank">http://project850.volvospeed.c...s.htm</A><p>Its funny, I've installed ALOT of stereo's in the past, and adding a sub to the factory Volvo stereo was about the most straight-forward thing I've done yet...I was sooooo carefull with this install; for some reason I was expecting the car to blow up or something...LOL
