1 - 11 of 11 Posts
Anyone use febi bilstien brand for subframe bushes??
Also I know IPD sells those subframe inserts, but I came up with an easy cheap solution. Windshield sealant (which is actually urethane) dries to an extremely rigid but still flexible state. What if we filled the voids of the bushes with this stuff let it dry (2-3 hours) and tada u got a solid mount. Could even fill the voids of the upper mount.
I'll get a tube of urethane and test this out.
The windshield material is too soft a durometer. I would use something a bit higher durometer. I know Liquid Nails Polyurethane Construction Adhesive is >60A, per the data sheet. I do not know the durometer of the other available polyurethane construction adhesives.
There are also polyurethane resins that can be bought with whatever hardness you would like, but it seems you are looking for a cost effective idea.
Poly yes is stronger. But I was just thinkin OEM bushes. I can get a tube of winshield urethane for $20. Probably enough in that tube to do all 4 sub-bushes and the upper bush.
I have window weld in my upper mount, it works great but is messy. You will need to do several layers with dry time for each. And I spent 24 hrs with the small heater going in the shop to make it cure faster.
I paid way less for the window weld online. Like $13
1 - 11 of 11 Posts
