I rebuilt a set of 2 hole SU's off an older 122 and installed those but can't seem to get them running right. I was wondering if someone could tell me what a good starting point is for the mixture nut? I am 1 full turn out from the nut being seated all the way in. I notice I occasionally still get some light backfiring through the exhaust after turning the car off so its still a touch on the rich side.
Also, this barb in the top photo on the top of the carb body to the right of the piston chamber(?), do I leave this open? or block it off? I'm thinking it needs to be blocked bc the idle speed screw is all the way out on that carb and I had to increase speed on the right to get them almost balanced but was hoping someone could confirm.
125584
125583
So that barb might be the vacuum source for the distributor. For tuning your of su's check out thr volvo green books. I believe they are available online if you look. Additionally Ron Kwas might be along later with more and better answers but he has a great website SW-EM Tech Articles that has a lot of great info for our volvos including SU carburetors.
Cheers
Daniel
Yes, I’d block of that nipple, false air coming in there.
Here’s one if the experts. Ron has good info too.
Awesome, thanks! Vacuum for the distributor makes sense, forgot they had that type. I'll check out the tech articles, block that barb off and go from there
C;
Daniel has it right! That hose barb is for Distrib Vac. and can simply be plugged when using a Distrib which doesn't need it.
A good starting point for mixture is typically 2 turns/12 flats down...BUT that is only valid when the starting positions of Metering Needle is correct with shoulder level across bottom of Dashpot:
...AND... starting position of Jet is Level across Venturi. See: SW-EM SU carburetors
Your two (Air Cleaner) bolt carbs are good candidates for the Helicoil mod! See: SW-EM_SU Carb_adding_Threaded_Inserts_for_Air_Cleaner
Thanks for the reference, Dan and Craig!
Cheers
