1 - 9 of 9 Posts
· Registered
It's an engine mount.
With the older V/S70's it was mounted against the firewall but I think Volvo made this construction to lower engine noise levels and maybe to protect the firewall construction from peak load at engine mount point during a head on collision.
· Registered
hey johann,
So if the S60 doesn't come with a sway/struct bar, where can I buy one? or that s60 doesn't need one?
quote:
Originally posted by Johann:
Originally posted by cal72:
The "black Bar that you see is to limit body roll by reducing the play in the struts. It's normally called an anti sway bar.
Hey Mr. [email protected],
Why comment if you don't know what's what.
Take a close look at it first.
· Registered
quote:
Originally posted by Kaizai:
Originally posted by Mr. T5:
hey johann,
http://www.ipdusa.com/ProductsList.aspx?subSubCategoryID=193
I don't see an S60 or 2000--> V70 in there.
There's just very little room for a strut brace.
On my carI can see marks of the hood isolation touching the "brace" already and this "brace needs the play is has to dampen the engine movement.
You could fabricate a fixed strut brace / engine mount but I'm afraid it will tear down the rubber inside the engine mount and it will pass on a lot of engine noise to the drivers compartment.
1 - 9 of 9 Posts
