Re: (ibanezplayer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>ibanezplayer</b> »</i></TD></TR><TR><TD CLASS="quote">well icebiker, I personally wouldn't worry about it, but this begs the question, HOW do you notice something like that? </TD></TR></TABLE><p>Good question...it's because I'm obsessed <IMG NAME="icon" SRC="http://www.vwvortex.com/zeroforum_graphics/screwy.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0"> with strange noises, especially if other cars of the same type do not make them. My front end sounds slightly different at 24K miles that it did when new. I've had my sway bar link rods replaced, and had the shocks, steering rack, subframe, suspension links, etc checked out a few times recently, and the dealer says all is tight and in good shape. But still have a subtle muted "bump/looseness" noise from the front end. Note that it doesn't <I>feel</I> loose, just makes this weird sound (that - of course - only <I>I</I> can hear when I ride with the dealer's tech <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> ). So, I started experimenting by trying to manually activate the suspension (pushing down on the car). That's when I discovered the noise I described above. It may or may not be the culprit. At one point, the dealer lubed the subframe bushings, which seems to help the matter, but as Helmut confirmed to me in an earlier post, these bushings are not grease fittings, so not sure if that's really a cure. Apparently my car doesn't fit the VIN range for the subframe bushing washer TNN either, so that isn't the culprit. <p>My biggest fear is 'living with it" until after the warranty expires, only to find out too late that a part was bad that could have otherwise been replaced under warranty. I'm just seeking a possible explanation, is all. <p>Thanks in advance for any theories <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
