1 - 14 of 14 Posts
Hi together,
i have a very strange Problem with my V50, 2005, 90tkm (round about 65000 miles) and the Premium Sound-System.
During a trip on last saturday my Sound System goes off while driving.
# If i push the "On" Button, the Premium Soung Logo comes, but after that nothing.
# The Display shows only the Temperature and Airflow
# if i push the "Sound" Button, i can select bass, treble, balance and so on.
# But the "Menu" Button don't show the Audio-Option (Only Car Options and so on)!
# The Navigation Monitor don't come's out if i press the steering wheel key or use the remote control.
# My parking sensor don't work
I can through out the RTI/DVD from MMM.
I find it interesting that the Sound-System Menu is "deleted" from the "Menu"-Button.
I also reconnect the Battery, but it dont work.
Any ideas? My nerves are quite frayed after the last problems. :(
Many thanks.
Daniel
Thank you for your reply.
The "Amp" ist the AUD Modul?
So i believe i checked it.. i checked also:
ICM: power yes, outgoing light signal yes
MMM: power yes, outgoing light signal no(?)
AFM: power yes, outgoing light signal yes
TMC: power ?, outgoing light signal no
AUD: power yes, outgoing light signal yes
GPS: power yes, outgoing light signal yes
That was yesterday. Today i ordered a MOST Bypass, i hope it will arrive tomorrow.
Do you still have the Grom connected in the MOST loop? Your symptoms are EXACTLY what I had after running the Grom data logger when I was having the tuning problems (before the FW version 10). After removing the Grom, the radio went back to normal.
Okay, today i checked all Modules if power is connected, yes.
All Modules (excepted the TMC) have an outgoing light signal.
I believe only the TMC-Module have a problem (but i don't really know it).
The MOST-Bridge don't arrived yesterday... :mad:
I tested also the Fibre-Line Cables, there are okay, too.
I don't know why, but is it possible that the "MOST Security" is activated and now all devices are offline?
Any ideas?
Thanks a lot.
Daniel
MOST security will only deactivate things, if one of the integrated parts doesn't aline with the stored codes or is different to the rest. What is the TMC supposed to be?
Okay.. that says when i bypass the (corrupt) TMC Modul (on the back, right side behind the sidepanel), the sound maybe goes on, because the MOST security don't do anything :confused:
What is TMC? What does that part do/control? Do you think the Grom is the root cause of your issues?
Again, I'm waiting for someone to tell me why MOST is better (really better) than wires, copper and plugs for car audio.....
He hasn't got the GROM box. He has Premium Sound so no Grom possible ;)
Discussion Starter · #11 · (Edited)
Oh sorry.
The TMC is the Traffic Message Channel Modul (i belive only in Europe). It works with the navigation system and gives you some informations abuut traffic jams and so on. The navigation system can calculate a new route to bypass this jam.
I believe the TMC is the same as the AFM Modul.
Edit: Here you can see my Menu-Options (Vehicle options, climate options) and the TMC Modul
http://imageshack.us/photo/my-images/843/tmcmodul.jpg/
http://imageshack.us/photo/my-images/716/klimafahrzeug.jpg/
Discussion Starter · #13 ·
What i forget to say..
two days ago my car get a new Motormanagement-Update. But after this update i drive home without any problems. One day later the problems began.
Another question: May i need a "online"-Vida and a dice Adapter to make a ring break test?
1 - 14 of 14 Posts
