1 - 10 of 10 Posts
Howdy all,<p>I have a noise like a clunk under low speed in first gear when I am in traffic when I accelerate and decelerate. in an old school RWD I would say it sounds like a U joint gone bad. Any ideas engine mount, tranny mount ???? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> Please advise.
Re: Strange noise (CM2RAS)
probably both
Re: (zabto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>zabto</b> »</i></TD></TR><TR><TD CLASS="quote">Have you done the axle ping fix? </TD></TR></TABLE><p>+1
Re: (zabto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>zabto</b> »</i></TD></TR><TR><TD CLASS="quote">Have you done the axle ping fix? </TD></TR></TABLE><p>Though axle ping would fit the accelerate/decelerate situation, it is not a clunk.
Re: (MagoonR)
It totally sounds like a clunk, I keep wanting to check U joints out of habit. FYI Rachel has 106000 on her.
Re: (CM2RAS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>CM2RAS</b> »</i></TD></TR><TR><TD CLASS="quote">It totally sounds like a clunk, I keep wanting to check U joints out of habit. FYI Rachel has 106000 on her.</TD></TR></TABLE><p>Then I recommend checking Rachel's upper motor mount and lower transmission mount; especially if they are the originals.
Re: (craina)
i get the same clunking you refer to .<br>i've had the:::::<br>Lower tranny mount ,<br>Lower torque rod<br>and upper engine mount all replaced with no change at all.<br>i may infact have Axle ping though..you may still want to try the mounts anyway due to your mileage <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <br>
1 - 10 of 10 Posts
