1 - 11 of 11 Posts
Hi, I just got a dice unit and I was able to monitor boost pressure via VIDA. The reason I bought DICE was to fix a mystery issue after installing phuzzy's tcv (speed sensor reading missing, oddly after clearing the DTC's and logging the sensors nothing is wrong).
Anyhow my boost pressure @ idle is set at 1020HPA which translates into 14.7 PSI. At half throttle it is running @ 1240 HPA which equals 17.9 PSI. I have not tried WOT but I am guessing it would be around 20 PSI.
I find this odd because my car is not tuned, just a DP and intake. Does anybody else have the capability to compare my numbers to theirs so I can make sure everything is alright? Also is VIDA the correct tool to figure out boost pressure, a buddy of mine has a boost gauge and at idle it reads 0 or -.
Thanks in advance :thumbup:
The intake resonator delete is all I've done and my stock boost peaks between 9-10psi.
At idle, it's all vacuum pressure and it tends to fluctuate based on outside temp and how hard the cars been running.
Not sure if that helps any :confused:
uh you should have about -17psi vacuum at idle and a max of +10psi WOT. If you rev in park or N its should go to 0 and stop. Anything outside those parameters is BAD.
i was having more or less the same issues as yours....
That is your manifold pressure, and it's atmospheric, i.e. zero boost. Boost is the delta above atmospheric, and untuned you should see 9-10psi, or about 24psi absolute, under a hard pull. You will not see boost pressure rise much by revving the engine without load.
Discussion Starter · #6 · (Edited)
Is VIDA an accurate way to read boost from the turbocharger or am I reading vacuum. In vida I monitor ECM ---> Boost pressure. Boost pressure could be a number of things lol. Doesn't make sense I would have boost @ idle
Edit: I have to measure multiple things to get the boost pressure. Taken from volvospeed:
Max Pressure Sensor Reading 1850 hPA = 26.83psi
Barometric pressure = 995 milbar = 14.4psi
26.83 - 14.4 = 12.4 psi Max Boost @ 4,400RPM
I figured the numbers were to high lol
Looks like you figured it out, but just a note that you will never read vacuum with VIDA, because the MAP sensor is before the throttle flap. If you install a boost gauge to the manifold nipple, you'll be able to see vacuum - although I can't imagine why anyone would need to.
That information "from volvospeed" is incomplete btw. Barometric pressure varies by weather and elevation. You, in RI near sea level will generally see a higher baro, and you can read it with VIDA, btw. Also, I don't understand why it says "max pressure sensor reading". I guess these were observed values on a given day by some person? Did you see 12.4 boost from a stock tune? If so, was it sustained?
I'll have to run it again, those numbers were somebody's from volvospeed, my max HPA is higher than that. If I am sustaining 12PSI on a stock tune is that bad? I will wait till my buddy comes by so he can work the computer while I drive otherwise it's a mess and a distraction
isn't stock boost supposed to be around 9.2 psi - 10 psi?
Yes but I've hit 12 to 15 before and it held for a while in 3rd and 4th gear going 40+mph
Sent from my iPhone4S using Tapatalk while on the toilet.
Not necessarily, but it's on the high side and could indicate a TCV or wastegate issue. That said, it's not really a bad thing, if the car's doing ok otherwise.
1 - 11 of 11 Posts
