Got new tires at 29k, alignment at 29.5, now have 34, and there is a nasty shudder in the steering wheel between 47-55mph only. Anyone else had this? I recall a few other members with nearly identical issues. Tried retorquing the wheels...cleaned the mounting surfaces, wheels were balanced with the new tires at 29k, and this wasn't an issue before the alignment...ideas?
Re: Steering wheel shudder (sanatarium)
alignment was done properly??? Tire pressure?? Bent wheels?? dont know as much as i wish but here are some ideas.
Re: Steering wheel shudder (vsweede40life)
Also check this out I figure that you would know more than anyone else lol.....<br><A HREF="http://forums.swedespeed.com/zerothread?id=115920" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=115920</A>
Your issue sounds like a funny front sway bar endlink. Mine is bad on the left side and it exhibits similar behavior. Especially over speed bumps.
I had same problem<p>Ebayed some hubcentric rings and worked like a charm.<p>At least for me<p>Good luck!
