1 - 8 of 8 Posts
my steering wheel puts too the left under braking. and wonders too the left when driving.
i have brand new rotors and pads
never got a alignment. would that fix the problem ?
tires are new.
i have 95k miles on the car.
Pulls to the left when driving and braking...have you checked your tire pressures? If all is even, could have a caliper issue, but considering your pull in regular driving, you should probably get an alignment.
95K..... check bushings too. Lower control arm busghings. Actually since they are $80 for a set you should probably just replace them if you plan on doing an alignment.
+1 & add a tie rod inspection. Since camber/caster isn't adjustable alignment won't make it pull unless something is worn or bent.
Is there a DIY on swede speed for doing lower control arms ?
^this is a great thread
the job is easy,
the hardest part is getting all the part numbers together. all the bolts and the correct sized ball joints -- and finding the best prices online.
1 - 8 of 8 Posts
