I had been experiencing a 1/8 in wiggle to the steering wheel lately. I disconnected the battery (waiting 30 min), used a small flathead screwdriver inserted into holes behind the steering wheel (one on each side), popped off airbag, and found the 19mm nut was finger loose. I had to tighten it 3 full turns. The steering wheel is tight now, feels great. After disconnecting the battery the whole process only took maybe 5 min.
It's kind of disconcerting that these things just loosen up like that. At least it was an easy fix.
My 2007 had this same problem when I got it in 2013. Found a thread about it somewhere, maybe on the UK forums? Did the same as you and problem solved.
