1 - 13 of 13 Posts
Discussion Starter #1
I need help in choosing which would be the best to do. my car is a 2004 s60 fwd and the turn radius sucks. at the moment when i turn my steering wheel to full lock my tires rub on the inside fender and I am just wondering if it would be better to replace the old steering stoppers or to install some wheel spacers and strive for the maximum possible turning radius.
Toss a few washers behind each bolt that hold the steering stoppers and see if that helps - about $2 bucks.
I put bigger rims/wider tires on and had a rub issue - the washers fixed it for me.
You don't even have to remove the wheels - just turn them to and get on your back.
Spacers look better.
Like with anything in life you have options.
A couple bucks for some washers...
Around $20 for new steering stops...
Or a hundred plus for spacers and lug bolts...
Go with the spacers if you want to push your wheels outboard a little more.
If you need help with the spacers from those in the know on SS; provide your wheel size, back spacing and tire size too.
Your radius should not "suck" on a FWD S60 unless you're running 235/45/17s
Your stops just may be worn out, (they do wear out).
Drive an R, then you know what an absurd turning radius really is!
235/45/17 is exactly what I am running.
Compared to many, even larger cars the turning radius does suck IMO....
Discussion Starter #7
I do run on 235/45/17s.
So, if I was running on smaller wheels I would have a better turning radius??
No... but a tire that is not as wide may not rub as much or at all...
Before I went to 17" rims and the 235/45/17 tires my stock 16" with (I think) 205/55/16 tires didn't rub at all.
Their are three different sets/ color steering stops available depending on how fat your tires are.
I don't remember what the sizes for the specific tire set ups are, but the colors are white, blue and black.
Just Google under images - volvo s60 steering stops- and you will get some pictures and a couple of sites that will tell you what color you need.
Or use the search function on this site and you should get more details.
Worst turning radius in any car I've ever driven... hands down. Still have a crush on her though ;)
spacers
I have an s60 AWD with 235/45/17s. I put 5mm spacers on the front wheels only and they minimally helped. I still get wheel rub though. Just an FYI.
5mm spacers should help a lot
1 - 13 of 13 Posts
