Can anyone explain the benefit of steel braided brake lines on a non-track car? TIA
Changing the rotor and pad size has a small effect on braking distance, but has a larger effect on cooling efficiency and heat capacity. Volvo probably changed the pads and rotors to cope with the extra mass of a 7 passenger SUV with the more powerful T6 or V8 engine. Smaller brakes may overheat causing warped rotors, or did not provide adequate repeat high speed stopping performance.Then why are there two different brake and rotor sizes with the xc90 if it doesn't change stopping distance?
Sent from the airwaves straight to your electronic viewing brain melting device
