Just took a look at my car sitting outside, and all the windows were foggy. It just finished raining pretty hard, but there's no real reason for moisture to be on the inside as the car's been sitting idle for the past couple of days.<P>Anyone know of common leakage points I should be taking a look at?<P>And on that note, what do you guys think of the defog system of this car. I find that I'll run the defog for a few minutes and once it disappears, turn it off as I'd do in any other car. Problem is, the fog comes back within a few short minutes. My guess is that since the car uses the A/C to remove the moisture from the air, I should probably be leaving it on a little longer than usual.<P>Comments?<P>
