My 05' XC is in trouble. This issue started on Friday. We went out to dinner in the XC and came home no problem. I needed to go back out about two hours later and it would not start. The motor turner over just fine but would not fire up. So I took the R instead. The next morning I checked to see if there were any codes with my reader and zero codes. I decided to try to start it again and it fired right up. I shut it down and started it up again with no issues. So I let it idle to get up to temp and took it for a test ride. Drove fine with no issues. Bring it back home and shut it down. Went to start it back up and it fired up but then quickly stalled out like either fuel or spark was cut. Any ideas, suggestions, anything? CEM, ECU??
Thanks in advance.
Thanks in advance.
