1 - 2 of 2 Posts
I've got this posted in the C70 section, but it applies to X70s
Pulled codes
SRS-422 Right SIPS bag signal missing
SRS-522 Seat belt buckle - Passenger faulty signal
SRS-605 Left side impact sensor faulty signal
Anyone ever dealt with these?
Are the wires under your passenger seat hooked up? Hard to believe both the buckle and the SIPS bag would go bad. These codes will trip if you disconnect the sensors with the battery still plugged in. Did you do that, or are these random codes that just popped up?
If all of these are truly faulty, you would need to source new ones. Have them cleared at the dealer and see which codes come back... that's the proper way of doing it.
1 - 2 of 2 Posts
