My g/f has a P1 S40 that has developed a strange hissing/rubbing/squealing noise upon accelerating. It sounds like it's coming from the wheels (more than one at the same time...?). It's not loud but it is disconcerting.<p>It sounds like the pads might be low, but like I said, it's only when accelerating. If the car is coasting or the brakes are applied the noise disappears. I've read some things about the driveshaft rubbing the exhaust but I figured that wouldn't apply to a FWD...<p>Any thoughts?<br>
Its the rear brake pads that have to be changed....I have a P2 S40 and thats the noise telling you that the rear pads are low and need to be changed....There isn't a sensor on the rear pads like the front brake pads on the 40s....so you have to listen for a noise from the brakes or check the pads regularly.
Ok, well I think the car is going to the dealer for service this week so hopefully this will be fixed. I'm just hoping it won't need rotors at the same time...
For anybody's reference in the future:<p>The rear pads were indeed gone, that was most likely the source of the noise. Unfortunately the rotors were very worn and needed replacement at all 4 corners (!!). <p>So $900 later, no more noise.
Re: (Crashy)
I knew that it was the rear pads <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0"> b/c it happened to me, but I was lucky that my rotors were alright. That sux man!
