1 - 8 of 8 Posts
Anyone ever have a vaccum line collapse under boost and cause a squealing noise?
No, but boost leaks at couplings can squeal. Didn't you just do a FMIC install? I'd go over all the hose clamps again when the engine has been running for a while and the couplings are all hot and soft.
Squeal started before fmic install after 18t was put on
IDK but a vac line won't collapse under boostm it could leak though, have you done a thorough boost leak test?
Or do you think it's just the turbo whining?
Cold weather squeal
I notice a turbo "squeal" when the air temp starts to cool. The other day we had a cool summer night and then the squeal came back. I'm not sure if your issue is temp related.
check the charge pipe hose to the turbo, also the did you use stock turbo pipe? i see that you have snaab there, so check also the hose that join the intake with the turbo.
1 - 8 of 8 Posts
