Discussion Starter #1
so i have a squeal coming from my front left wheel area. at slow speeds it almost sounds like a squishing noise!
i have changed my wheel bearing, and am not sure what direction to go next. any advice for a do it myselfer? the only things i can think of are the axle or there was a small boot/circular seal that came out when i did my wheel bearing. i did not lube it when re installing.
I had a sttange squeling sound that was coming from the front wheel once and it turned out to be the heat sheild rubbing on the rotor. Mechainc was nice enough to point it out and fix it for free. I miss that shop!
Pretty sure it is your dust shield.
Does the squishing noise occur only when your driving over your mother-in-law? Or under normal driving conditions?
