Discussion Starter #1
Hey guys I cant quite find the answer, could I do just springs with the stock struts or would that be ill advised. How about springs at first and then when the money is there change the struts?
Model of Volvo would help but either way, you would be doing double work
^ +1 Plus probably not advised; depending on the rate of the new springs they may be too much for the stock shocks.
you'll bounce around like a little kid a a jumping ball if you pair stiffer springs with the stock struts.
