1 - 2 of 2 Posts
Is there anyone know where can I get the speed signal from my S60 year 2001?
I want to get the speed signal to my DEFI ZD dashboard.
I tried to connect with ABS speed sensor but it's not work. There is 2 wires on that I connect with one wire. Maybe I will try the another one.
Or I have to get the signal from CAN BUS ? Do you know where?
<img src="https://i.ibb.co/mhmP7b1/IMG-2673.jpg" alt="IMG-2673" border="0">
In the manual mention as below details
<img src="https://i.ibb.co/sVNWtQQ/LINE-P2019825-191811.jpg" alt="LINE-P2019825-191811" border="0">
Wiring of speed and tachometer signal wire
1. Disconnect the negative(-) battery terminal.
2. Connect the green wire(SP) to SP signal of ECU.
3. Connect the blue wire(TA) to TA signal of ECU. If the tachometer signal wire
of ADVANCE series is already wired, connect only the green wire. (Do not
use the speed and tachometer signal wire included in this product.)
 ⇒ Refer to how to solder and how to use the solderless connectors.
4. Connect the speed and tachometer signal wire to ADVANCE Control unit. (In
case the wire is already connected, skip this step.)
5. Connect the negative(-) battery terminal.
6. Set the speed pulse, number of cylinders, and tachometer response after all
the installation and wiring are done by referring operation section.
Discussion Starter · #2 ·
<img src="https://i.ibb.co/TPXQT7y/1566742085765.jpg" alt="1566742085765" border="0">
Is it the white wire from pin no.3?
1 - 2 of 2 Posts
