Spacers and stud conversion kits
2.7K views 7 replies 6 participants last post by  maronha
Hello,
I'm hoping someone can recommend a good wheel stud conversion kit to run with spacers. (10mm front, 15mm rear)
I need to replace the wheel bolts on my car as they're pretty rusted and generally beat up. I was thinking about getting some spacers while I'm at it as well to eliminate the rub, and have seen that a wheel stud conversion is generally smart when doing this. Which brand of wheel studs should I be looking at?
I looked these up and they're really tempting since their half the price of H&R's spacers. Only thing that bothers me is that they're not silver so I feel like they'd stand out against the pegs. Do you have any pictures of them on the car?
Use this thread if you're unsure about the specs: Stud Conversion convo from 2007
In terms of spacers, just make sure they're hub centric (65.1 mm) and that they leave enough threads on your studs. I got my parts from Motorsports Hardware a couple of years ago, bought the spacers from IPD (I got the H&R ones) and haven't looked back.
My only advice is to use generous amounts of red loctite on the studs.
#8 · (Edited)
I used them also. here is a
contact. I found a 10% off coupon code online. If you want to save a couple bucks look for one.
This post has been deleted
