1 - 20 of 94 Posts
We screwed up and never ordered the heating steering wheel option when we did OSD (never dawned on us until I got an Audi that has one... what a difference). Anyways, I did a good bit of research on how to retrofit our XC90 without paying ~$1,000 for the official Volvo accessory (Part Number: Kit057), and here's what I found out
For reference, the Volvo Accessory Kit includes:
  • 32204779 - Steering Wheel (charcoal)
  • 32266026 - Steering wheel module
  • 31428189 - Software
My DIY Kit:
  • Steering Wheel - I was able to find a used heated steering wheel on eBay from a totaled 2018 XC90 (rear impact / no airbag deployed) with ~10K miles for $150. Part Number: 31407817. Most salvage companies list the part description incorrectly, but it's really easy to tell if a steering wheel has the heater element by looking at the wire harnesses. Steering wheels without the heater element only have one wiring harness that plugs into the module at the 1 o'clock position (for the steering wheel controls). The heated steering wheels have a second wiring harness at the 6 o'clock position. These steering wheels are also universal with other SPA vehicles (e.g. S90, V90, XC60, etc.), so search those models as well. You can type the part number into Volvo's parts website to see if it will fit your vehicle. I've included some reference codes below to help you decipher the descriptions
  • Module - I thought I could get away with using the module that was already in my car (Part Number: 31443883) as it has a connector for the heater element, but that is NOT the case. If the car came from the factory with a heated steering wheel, it would be programmed to use this module. However, the required retrofit software can only "communicate" to the module listed in the kit (Part Number: 32266026). This set me back $135
  • Software - Dealer had to program the software (Part Number: 31428189). Software $35 / Labor (1 hr) $ 115
  • Labor - I installed the module and steering wheel myself using these instructions. Really straight forward. I was concerned that you wouldn't be able to turn the steering wheel without the car on, but I had no problem
Total Price: $435
I ended up spending a little more than originally planned, but it's worth it.
Volvo Steering Wheel Description Codes:
  • RT02 - Heated Steering Wheel
  • FL01 - Charcoal base color interior
  • RU02 - Steering wheel, 3 spoke, leather with unideco inlays
:beer:
I guess I’ll have to keep an eye out for used steering wheels :thumbup:
@satrya Correct, and I did the labor myself
I decided to do a little write up to share my experience as I couldn't find any good information when I was researching... I originally thought I could use the existing Module (aka gear lever carrier) since it had the connection for the heater element, but as it turns out, it isn't compatible with the retrofit software. But, I did find out that any SPA steering wheel with the heater element will work... it doesn't have to be from an XC90. Just trying to save the next person some time and money
P.S. My original steering wheel is for sale in the Classifieds (HERE) if anyone wants to start a fun project (wrap it in alcantara or perforated leather)
Aside from having to remove the airbag, was anything else in the SRS system impacted? For instance, I am looking to retrofit a heated steering wheel on my 2019 Suburban, but it requires replacement of the clock spring. Because there is not a specific accessory kit for the upgrade, the GM dealers will no sell the individual parts or make the installation. Additionally, unless sanctioned by GM, I do not want to make the upgrade in case it causes a problem that would prevent the airbag from deploying.
Good build. I'd imagine most folks would rather just pay the $1000 at this point, but good to now it's not too crazy to do. If you had been able to find the module in a junk yard too that probably would have been less and got you under $400. I'll probably use this info to help folks visualize the value of us doing it for a grand. I hate getting used cars in without heated steering wheel, we order every car with it and when I get a custom order request without it I try very hard to talk them into it. Resale value alone, plus like you, once you have it, it's so very nice.
Discussion Starter · #11 · (Edited)
You can definitely do it, I'm just not sure if anyone's figured out how to get the paddles to work on a vehicle that wasn't originally delivered with them.
If you look at the picture I posted above, the steering wheels that have paddles have additional wires that go into the green connector at the 1:00 position. So the hardware is there, it just all comes down to the software.
I’m tempted to do this but all the Volvo wheel part numbers I’ve found say “except for T8”
Banned
Hmm I wonder if its same parts for s60 2017 with no heated wheel .
Discussion Starter · #14 · (Edited)
I'm tempted to do this but all the Volvo wheel part numbers I've found say "except for T8"
I have no idea why the 'Twin Engine' vehicles are excluded. Anyone know why this is?
Discussion Starter · #15 ·
The steering wheel module would be different (the one listed above has the rear windshield wiper settings at the end of the stalk, that aren't relevant to the S60/S90). See THIS link for the parts you would need. Note that the steering wheels are all interchangeable, but the module and software are different.
Thanks so much for sharing! I too didn't value a heated steering wheel from OSD but with our T8, avoiding turning on the main heater means more electric mileage. This is on my to-do list - if the T8 difference is ever sorted out!
While its not directly relevant, I added paddle shifters to my 2001 BMW 740i. In that case it involved adding the paddles and swapping the clock-spring to get two additional contacts (they were originally intended for heated steering wheel in that replacement clock-spring). The rest was just adding wires from the clocks-spring down to the shifter - which was effectively a simple switch. The paddles just mimicked the contacts made by the shifter. So if the additional contacts on the steering wheel are then than it might be possible without too much difficulty. As was noted, the only question would be if the software would get in the way but using the principle of the paddles mimicking the make/break of the switch just as the shifter does then it might be seamless.
I'm don't have to worry - my V90 R already has paddles which I enjoy..
I did the swap..
Does anybody know, whether steering wheel replacement, requires wheel allignment afterwards?
Can the steering wheel, be installed off-center?
I ve been told that it can only be installed in one certain position.
I replaced mine and the steering wheel feels, its not centered when the car drives straight..
Discussion Starter · #19 ·
No alignment is necessary. The connection between the steering wheel and the spindle is a hexagon (see photo below). It is possible to install the steering wheel off center, but you'd be 60 degrees off center.
Reactions: xc90mb
Are you sure about it?
Seems logical but is it the same for the sports steering wheel?
60 degrees is a lot, i feel my steering looks at 12:30 instead of 12:00..
1 - 20 of 94 Posts
