Source of oil / power steering fluid leak
2000 V70R. It stays under a car cover in the garage over the winter. I start it every so often during the winter months. I moved it out of the garage over the weekend only to find a good sized (5 inch) oil puddle under it. I assumed it was oil as it was clear and I had just changed the oil before storing the car for the winter.
Anyway, after much hunting I just can't find the source of the leak. It seems to be dripping from the bottom of the a/c compressor making me think it's actually power steering fluid from the p/s pump above it. The fluid is so clear - almost too clear to be motor oil.
The p/s pump seems to be dry - just a little damp on the surface of the hose that goes to the reservoir. The line that goes to the rack is dry.
I don't think the turbo return line is in play - as the leak is more to the front of the car. No leak from the base of the dipstick.
Has anyone encountered a leak which appeared to find it's way to the bottom of the a/c compressor before dripping on the ground? I just can't seem to find the source.
Thanks! Steve.
Thanks! Steve.
