1 - 14 of 14 Posts
Discussion Starter #1
Any suggestions on best/most economical material for lining interior to reduce engine/road noise?
Hi John! I'm looking into this too right now, actually. I think there's a couple routes to go, but I was planning on going to a place like Home Depot and finding a dense material (like a heavy rubber matting) for sound dampening. I think the rule there is to cover 25% of the major surfaces. And then I was going to go to a carpet or upholstery store and get some thick jute carpet padding to go over that for heat insulation. That's pretty similar to what came in the cars stock, I believe. And it's way cheaper than using a Dynamat material.
I'll let you know what I end up actually purchasing.
Discussion Starter #3 (Edited)
Thanks, akierstein. Seeing alot of info on line from Dynamat to FatMat to Peel and Seal. Will want something fairly cheap, but not smell like asphalt, as some of the mentioned products have been known to do. Anyway, given her some lovin and would like to get a little less road noise
I am considering FatMat for my wagon. The reviews are pretty spectacular and it is not nearly the cost of Dynamat. Ebay has had the best prices so far. Keep us updated on what you decide to go with!
Zach Silver
Discussion Starter #5
Hi Zach...I did decide to go with FatMat based on reviews and advice from user on another forum who had used both products (FatMat, Dynamat) and advised that they were indistinguishable from each other. I'll update this post with pictures and effectiveness after install.
I'm going to try out the Reflectix under jute padding under the carpet. I just bought some Reflectix from Lowe's ... it was $16 for a 2'x25' roll. Should be enough to do the whole car. Didn't get to an upholstery shop today to pick up the jute, but I'll report back on cost. I'm expecting the whole situation to be reasonably good as far as sound and very good as far as heat insulation, but I'll let you know. It's also so cheap that if it sucks I'll just spring for the good stuff later. I'm just going to use foil tape to put down the Reflectix and a minimal amount of spray glue for everything else. The carpet is easy to remove.
Let's compare notes in a few months!
Did anyone ever do the sound dampening? If so, what did you use and how well did it work?
Correctly installing a new shift boot (in a stick-shift car) will greatly reduce road/engine noise and heat/air intrusion.
George Dill
Any idea where one can find a new boot? Then, we can discuss how to "correctly" install it. I had tried to patch holes on the boot with duck tape. Did not work so good. Any good tricks on how to patch a rubber boot?
Discussion Starter #12 (Edited)
I did install the FatMat and it has provided some improvement. However, I can't comment on how much improvement until I finish up the interior with an additional layer of pad and carpet. I also put some butyl sheeting behind door panels, which has helped.
Edit: I did hear from another owner that the stock shift boot provided greatest improvement, to re-inforce George......google "Tom's 1967 Volvo" for photos and a flyer
IRoll Mike, VP-Autoparts, Eric Hamlet in Torrance, CA and Olof Malmberg (Vintage Import Parts) in Washington and BC should ALL have shift boots.
1 - 14 of 14 Posts
