1 - 19 of 19 Posts
Moderator
Bought this thinking I would need it however I drive my R maybe a mile a day now so this is just over kill. It's mint, never used and ready to go. It's just been sitting in the parts pile waiting to go in. Asking what I paid for it after customs duties etc. 285 shipped to your door anywhere in the us!
Moderator
Discussion Starter · #2 ·
Sold, thanks for the all the interest!
Moderator
That might have been a record!
I'm not sure , but it looks like that the 90 degree pipe has wrong direction. It has to be like in the next pic :
Yea I bought this because I'm building our shop R up to about 450 whp and viva has been out... So am I hearing this right that it won't fit right?
Sent from my SM-N910P using Tapatalk
the simpler way to check it is to go under the car and check it , but I'm afraid of that I'm right
Yeah the one you want for a P2 is from the diesel in Europe. This does not look like it would fit on an S60R. I have the one from the diesel and looks just like the stock one but larger. Tubes going in the same direction as stock.
Moderator
Discussion Starter · #13 ·
Moderator
Discussion Starter · #14 ·
Again the diesels are still smaller then the RS as the pic above shows. The RS cooler is over 25% larger if you count by levels.
^ this is definitely different than the one pictured in the OP.
"Enough hose will fix any problems that should arise"
Nope wont fit the R without bending the crap out of stock pipe or cutting and welding the right pipe and facing it up. I tried fitting one on my car and she wouldn't fit without serious modding to it.
And I don't think its any different in size than the one I have, if it somehow is it would be very minimal.
The cooler the OP posted WILL NOT fit the P2 engines without modification. I have first hand knowledge of this because I sourced the EXACT same item from the UK and had to have the 90-degree bend on the right rotated 45-degrees so it faces up instead of to the left.
Any shop that specializes in radiators can do it. Just make sure they pressure test it after the mod.
1 - 19 of 19 Posts
