1 - 13 of 13 Posts
Just wondering why they made the volvo s60s FWD. I know it cheaper but i wouldnt mind paying a little more. they made teh old one with RWD, so why FWD. RWD is almost superior in all aspecs. Just wondering if anyone knew.
Re: So why FWD volvo? why? (T5atl)
Superior is subjective. Quite simply, Volvo didn't have the $$$ as a standalone so once the 850 came out and was successful, the FWD platform stuck. Also, a transverse engine FWD layout is more crash friendly which follows the safety concept.
Re: So why FWD volvo? why? (MagoonR)
Quote, originally posted by MagoonR »
This is the main reason, all Volvos today and in the near future will be transversely mounted engines with FWD or AWD.
Re: So why FWD volvo? why? (Warpedcow)
Quote, originally posted by Warpedcow »
Also, FWD is more efficient. Shorter drivetrain = more WHP! http://********************/smile/emthup.gif
lol, k, I was having a discusion(a nice argument) with a friend about it. well know i know alot more about FWD so thanks
Re: So why FWD volvo? why? (darylkaiser30)
Quote, originally posted by darylkaiser30 »
WRONG
Banned
In the scheme of things, the hierarchy of performance handling goes something like this:
#1. AWD. Superior traction, even at the expense of some moderate understeer. Generally good weight distribution, but the added weight of the powertrain can be an issue. Viscous slip and Torsen units are rugged and almost maintenance-free. Some mechanical complexity due to plethora of CV or U-joints. Generally more expensive to manufacture and increases vehicle assembly costs.
#2. RWD. Generally very good weight distribution. Excellent stability due to low polar movement (in front engine, RWD cars). Predictable transient response. Ability to invoke throttle oversteer, which (in small quantities) can be a useful on the track. Excellent turning circle due to increased steering lock of undriven wheels. Very good traction on hard acceleration, as weight shifts to rear. Weakness are U-joints, except in torque tube or IRS set-ups where vertical range of drive shaft motion is limited.
#3. FWD. Economical packaging for lower assembly costs, as the engine, transmission, front suspension and steering system can be built on a sub-frame for rapid installation into the vehicle chassis on the assembly line. Good traction on moderate acceleration -- especially when surface is slick, otherwise slightly less capable than RWD. Moderate to heavy understeer due to impact of powertrain on chassis weight distribution. Acceptable transient response, but limited by poor weight distribution. Weakness is in CV joints which are expensive to replace and tendency to wear front brakes/tires more as a result of weight distribution.
The popularity of FWD is more a testament to good marketing than an interest in vehicle dynamics. For the everyday driver, FWD provides a good balance between traction and handling. As the demands of the road increase, however, RWD provides more rewarding handling at the limit of adhesion. In slippery conditions, AWD is a definitely an asset.
Bollocks.
Re: So why FWD volvo? why? (JRL)
WRONG
OK, so it seems I have been grossly misinformed about FWD vs RWD and I apparently don't understand the basic mechanical principles at work here. I read the response by RWP and I still don't see why a shorter drive train wouldn't transmit more power to the wheels as opposed to a longer drive train in a RWD set up. Also, with the transversly mounted engine aren't there fewer joints that power has to be transferred through? Please advise further!
Re: So why FWD volvo? why? (todd.tx)
Quote, originally posted by todd.tx »
Hotlanta, well that explains it. Ever driven in snow and ice? Todd
Indeed. Try to go snowboarding in a RWD and see what happens...
lol i live in geogria. Snow? whats that lol
i guess i forget that these cars were made for sweden and snowy places
i love snow in my camaro
Re: So why FWD volvo? why? (Bender)
Quote, originally posted by Bender »
]i love snow in my camaro
Do you have a mullet and wear jeans while you ski as well?
Just kidding! http://********************/smile/emthup.gif
1 - 13 of 13 Posts
