I have a 96 855 w/ 190k+. Trans has really started fading(FAST), it's dropping fluid like a VW. Sourcing a replacement now, and I know they're out there.<br> My question is, being still semi-new to Volvo, What other things are good to take a look at / replace while the subframe is down?. IPD sways will go in, as well as a new rear main seal. Is there anything else?, these cars are a little more expensive to open up. Any input would be cool.<br> Thanks! Scott
Re: So when the trans comes out, what other parts are good to replace/ check out (realsicksince88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>realsicksince88</b> »</i></TD></TR><TR><TD CLASS="quote">I have a 96 855 w/ 190k+. Trans has really started fading(FAST), it's dropping fluid like a VW. Sourcing a replacement now, and I know they're out there.<br> My question is, being still semi-new to Volvo, What other things are good to take a look at / replace while the subframe is down?. IPD sways will go in, as well as a new rear main seal. Is there anything else?, these cars are a little more expensive to open up. Any input would be cool.<br> Thanks! Scott</TD></TR></TABLE><br>Good time to replace those motor mounts <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
If you are loosing fluid, fix the fluid leak! You may not have a bad tranny at all.
Re: (RussBert)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>RussBert</b> »</i></TD></TR><TR><TD CLASS="quote">If you are loosing fluid, fix the fluid leak! You may not have a bad tranny at all.</TD></TR></TABLE><p>Yep! May be a bad seal where the torque converter is. Cheap part. <br>Replace the rear main seal on the engine. No question about that!<br>Not doing the RMS would be throwing your money for labor away.
