1 - 20 of 28 Posts
I like the rims.<br>IPD VMS Wheel - Hyper Black Finish<br>Specs: 26 pounds actual weight<br>ipd#: IPDVMS18838<br>Fitment: 18x8 inch size with 38mm offset<p>Will NOT fit R models<br> <br>Where can I get these style rims for the s60r, or is there a solution for these?
The problem is that the wheels don't clear the R calipers. You could get spacers, but i'm not sure how much you have to space them by, you're better off asking lucky about that.<p>Otherwise you could remove the brembos.....lol, no.
Re: (cmurphy2266)
I think you had to use 10 mm spacers to make it work? Either way, paired with the wheels offset, this resulted in the wheel sticking out too far IIRC. IPD basically didn't recommend it and I don't believe anyone has put them on an R for this reason. There have been numerous threads about potential group buys for these style rims, but none have come to fruition. I think HRE has a rim this style, but it cost $$$<p>From Ask IPD Forum:<p>As for fitting these to a P2R, don't hold your breath. The 10mm of spacing required to properly clear the R calipers means the hub doesn't engauge the wheel and therefore a hubcentric spacer is required. This adds considerably to the overall cost and puts the wheels so far out that with stock body parts it just isn't viable.<br><BR><BR>
<i>Modified by jdog at 10:24 PM 6-27-2009</i>
Re: (jdog)
If your heart is in getting this wheel, you'd absolutely require spacers - but not just any spacer...you need to get "hub centric" spacers. H&R makes the correct spacers for our hub diameters. You need to look carefully in your purchase. I don't believe H&R makes 10mm spacers - last I remember, VIVA carries 10mm, but expensive. H&R carries 5mm, 15mm, 20mm, etc. <p>And once you get to that size spacer, you <B>might </B>get into other issues with them, such as needing your fenders "rolled" to allow for the width increase in your track.
If you like wheels like the IPD ones, then look at these. I tried getting them but they were backordered until the end of June (this week). I may look into these again in July. About $155/wheel<p><A HREF="http://www.msrwheels.com/auto_car_wheels.cfm?id=411" TARGET="_blank">http://www.msrwheels.com/auto_...d=411</A>
Re: (IwantaS60R)
Those will fit the R? With or without spacers? Good find. Also, know how much they weigh?
Re: (jdog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>jdog</b> »</i></TD></TR><TR><TD CLASS="quote">Those will fit the R? With or without spacers? Good find. Also, know how much they weigh?</TD></TR></TABLE><br>24-25lbs I believe<p>no spacers necessary<p> <IMG SRC="http://img33.imageshack.us/img33/5678/img00107u.jpg" BORDER="0">
Re: (IwantaS60R)
That would make for one rough ride!! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
Re: (IwantaS60R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>IwantaS60R</b> »</i></TD></TR><TR><TD CLASS="quote"><br>24-25lbs I believe<p>no spacers necessary<br> </TD></TR></TABLE><p>Nice! Is that your car? Would they stick out too much with 10mm spacers? (I'm using these on my pegs all around right now - although I could just sell the spacers if I switched to these rims)<p>Thanks, Jim
Re: (jdog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>jdog</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Nice! Is that your car? Would they stick out too much with 10mm spacers? (I'm using these on my pegs all around right now - although I could just sell the spacers if I switched to these rims)<p>Thanks, Jim</TD></TR></TABLE><p>yup, my car. I went to test fit the rim with a rim they had in another PCD. The offset is 35mm so 10mm would be ill-advised. <p>
Re: (T5 for Life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>T5 for Life</b> »</i></TD></TR><TR><TD CLASS="quote">That would make for one rough ride!! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> </TD></TR></TABLE><p>My "R" rides on rails. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
Re: (IwantaS60R)
Do you have any clearer pictures with the rims installed (with tires)?<p>I have been looking for a black rim with red stripe (or maybe silver stripe) around the outside and this looks good (CSL style) <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
Re: (IwantaS60R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>IwantaS60R</b> »</i></TD></TR><TR><TD CLASS="quote"><p>My "R" rides on rails. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> </TD></TR></TABLE><p>Yeah, in tampa its no problem.
Re: (ClemsonS60R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>ClemsonS60R</b> »</i></TD></TR><TR><TD CLASS="quote">Do you have any clearer pictures with the rims installed (with tires)?<p>I have been looking for a black rim with red stripe (or maybe silver stripe) around the outside and this looks good (CSL style) <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> </TD></TR></TABLE><p>Nope, haven't bought them so no pics with tires. As mentioned, I was test fitting them just in case I wanted to go through with a purchase. They were back-ordered at that time anyway.
Discussion Starter · #15 ·
Re: (T5 for Life)
Just to be clear these fit the the car perfectly, just like stock rims? what tire size do they call for?
Re: (kitkat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>kitkat</b> »</i></TD></TR><TR><TD CLASS="quote">Just to be clear these fit the the car perfectly, just like stock rims? what tire size do they call for?</TD></TR></TABLE><p>They're 18x8, which is going to be the same size as 18" Pegs....so 235/40-18 should work just fine. <p><A HREF="http://www.ipdusa.com/New-Wheels-Have-Arrived/blog-74" TARGET="_blank">http://www.ipdusa.com/New-Whee...og-74</A>
Re: (IwantaS60R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>IwantaS60R</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Nope, haven't bought them so no pics with tires. As mentioned, I was test fitting them just in case I wanted to go through with a purchase. They were back-ordered at that time anyway.</TD></TR></TABLE><p><br>Excellent find Jerome - I'm going to look into this wheel option!
Re: (mpdbrown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>mpdbrown</b> »</i></TD></TR><TR><TD CLASS="quote">very confusing. the wheels ipd says wont fit actually do fit?</TD></TR></TABLE><p>what you talkin bout willis?!<p>They're talking about the MSR wheels iwantas60r linked. I don't know why m3nt0s linked to the IPD website.
Discussion Starter · #20 ·
Re: (IwantaS60R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>IwantaS60R</b> »</i></TD></TR><TR><TD CLASS="quote"><br>24-25lbs I believe<p>no spacers necessary<p> <IMG SRC="http://img33.imageshack.us/img33/5678/img00107u.jpg" BORDER="0"> </TD></TR></TABLE><p>Went to the site, looks odd when you have 9 holes for lugs but only put on 5. is this how they are??
1 - 20 of 28 Posts
