1 - 20 of 24 Posts
So I says to myself "Self I says, I really don't like torque steer, where did my AWD go?"
I was in 2nd gear entering a highway, I was cruising at about 40km/hr @ ~3000RPM and the way cleared and so I got into the throttle when I heard a nasty snap sound and felt the car pull hard left and felt thud-thud-thud-thud. I was sure I had blown the front right tire [edit: LEFT tire] but then it was smooth again ???
I entered the highway cautiously and eased back into the throttle and things felt 'okay'. Got off at the next exit to have a look and saw nothing wrong with the tires. That's when it occured to me that the AWD was gone and it was easily confirmed by easy wheel spin in 1st and 2nd (3rd too, I think).
I also hear/feel a light clunking/clacking when backing up and/or making parking manouvers.
Yes, I'll be into the dealer asap but is there a way in the mean time for me to know what went bust? Was it the angle gear or the collar gear (or something else)?
I'm at 48K Km's and have a stock ECU.
For cross-posting purposed here's a useful link:
http://forums.swedespeed.com/zerothread?id=113680
This car and it's owner are really sad without it's AWD
LTA
Modified by LTA at 11:49 AM 5-15-2009
Re: SNAP! Thud-thud-thud... AWD gone! Angle gear or collar gear? (xman03)
Sorry to hear, let us know how the repair goes
EDIT if it were the angle gear failing in catastrophic fashion, there's a good chance you would have seen fluid....
some people crawl under the car and spin the driveshaft, if it spins freely, the collar is dead
then there is also Jim Lill's angle gear test...but I don't think that would help you in this situation.
Re: SNAP! Thud-thud-thud... AWD gone! Angle gear or collar gear? (LTA)
Well, you can do the JimLill AWD test (even though I'm / we're / you're pretty sure it's already gone). Jack up a front wheel and spin it, whilst looking under the car to visually check (as opposed to what, audibly check?
) if the driveshaft turns. If it doesn't, no AWD (failure of sleeve or angle gear). Like I said though, it's pretty much guaranteed though. Sorry man...
-Steve
Sounds like it could be either. I'm leaning more towards collar but at this point it sounds like the angle gear is coming out anyway so make sure they check the collar gear. It'll probably be seized on the trans anyway.
Re: SNAP! Thud-thud-thud... AWD gone! Angle gear or collar gear? (PhilUp)
Quote, originally posted by PhilUp »
Jeez a bunch of AWD failures lately. Wonder who's next...
No kidding. Maybe we should start a SS AWD failure support network...every time someone's AWD fails AND if they are out of warranty, we all mail them $1 to help lessen the sting a bit. We could set it up via paypal...
My hand is up, but you can't see it. Hopefully my mangle gear doesn't notice it either.
Re: SNAP! Thud-thud-thud... AWD gone! Angle gear or collar gear? (FEO)
Thanks for everyone's sympathy but I'm not too bothered by it and just glad it happened after the winter (and I'm still under factory warranty). I plan to keep this car for the long haul so I'm glad I have VIP (but what happens after that? Maybe IPD has heavy duty replacement parts by that time).
Quote, originally posted by xman03 »
Out of curiousity what are your driving habits like? Ever launch the car?
I've launched it a handful of times, but nothing too crazy and nothing recently either (last time was probably a year ago).
I have been driving pretty easy for the last few months.
Quote, originally posted by FEO »
First thing I looked for was fluid but didn't see anything (and their was nothing after it sat over night).
I'll see if I can reach under to spin the driveshaft.
I was planning to go in for service soon for a bunch of small things but I guess this raises the urgency and the length of time I'll be in an NA S40
LTA
The shaft rotates so I guess that's a good indication that the collar gear is pooched.
This car sucks in FWD http://********************/smile/emthdown.gif
Can't believe how easily she breaks the front tires loose
Going in for service next week...
LTA
So Im still trying to understand this angle/coller gear failure nonsence. Was the angle gear built with weak components or we just cant drive this car that hard? The drive shaft test is teh easiest way to determine the failure of the AWD system?
One of these days i need to read these threads because i am still trying to understand why so many of us are having this issue but i dont even know where to start since there are so many of them!
My car is in the shop for the same exact problem...it sucks don't it. I'm hoping that mine failed at the collar gear because according to my 3mo/3000mi waranty from the used car dealer, my "powertrain warranty" only covers internal components of the engine and transmission. What a joke. So I just hope it isn't the angle gear and they have to pay up.
I put my car up on a lift and spun the driveshaft, no resistance from the rear wheels at all.
Re: SNAP! Thud-thud-thud... AWD gone! Angle gear or collar gear? (Token Blk Guy)
Quote, originally posted by Token Blk Guy »
Angle and Collar Gear 101
1) Volvo's engine is mounted transversally (axis of rotation is from left to right). Not all car brands use this engine setup
2) the angle gear rotates power 90 degrees, in order to be able to send power to the back
3) the collar gear is a hollow coupler between the shafts of the transmission and the angle gear
Quote, originally posted by LTA »
Damn straight. I only learned of my AG failure when trying to get up a snow covered road (couldn't have been more than a 3% slope...no joke)...the front wheels spun like no tomorrow, had to be flatbedded 100 yards to dry ground. what an embarassment, hassle and major punch in the wallet....still love my R, but the AG is its Achilles Heel. Volvo needs to be flogged severely for making such cheese.
There is a 10 plus page thread started by adykes with a more discussions than you care to read...
Re: SNAP! Thud-thud-thud... AWD gone! Angle gear or collar gear? (Needsdecaf)
Thanks guys for the 101 its all coming to me, Even tho i cant see the second picture ( some of the pics ar blocked on this site) the first pic made it clear.. i got my R with 15K on it and im getting a little nervous about this system failing!
Im going to check out adykes thread!
Discussion Starter · #18 ·
As most suspected, the failure was with the collar gear (or sleeve as it's called in Vadis).
Angle gear was fine http://********************/smile/emthup.gif
I might get the terms wrong but the way I understand it from my tech is that from the factory the case is assembled completly dry but the new collar gear gets installed with lots lubricant to fill the case (as part of the service kit, I think) which is intended to increase longevity by keeping any wear particles from building up in the wrong places.
My tech is simply FANTASTIC, his attention to detail and throughness sets the bar very high. I gladly drive 25mins and pay a $7 toll one way to get his service! He addressed and solved a number of other related and unrelated issues (in addition to the 5 page list I left him with).
All was covered under factory warranty (just had to pay to patch my tire, which in retrospect should be covered under VIP less a $25 deductible). Hopefully this collar will last well beyond my VIP contract term.
I love my AWD R!
LTA
this sucks man sorry to hear. just had the say thing prity much happen to me i order the collor gear svc kit and a spair axel seal and 1 hr and 20 mins later i had AWD agen. I dont recmand you trying it in that time fram thow
http://forums.swedespeed.com/zerothread?id=119473
thats my post about what happens. dont mind some the thing that were sead people have big mouths LOL
Discussion Starter · #20 ·
Re: SNAP! Thud-thud-thud... AWD gone! Angle gear or collar gear? (VolvokidS60R)
Quote, originally posted by VolvokidS60R »
Saw your thread, some useful info there along with some very 'colourful' language enhacements LOL.
My tech did mine in 57 minutes using one hand and including the time to walk over to get the parts. JJ... I'm not sure how long it took but I know there was some extra sweat and time in getting off the sleeve which was siezed on.
I'm just glad my AWD is back. I think the 4-C is really bad (confused) when there's no power to the rear (that 4-C is expecting). Would you believe there's a member here who actually removes his prop shaft in the summer
LTA
Ps. How long would it take you to swap in my four TME springs and rear anti-sway bar?
1 - 20 of 24 Posts
