1 - 12 of 12 Posts
A 2005 XC90 popped up in the local junkyard and I was thinking about snagging the the brakes off of it for an upgrade on my XC70. Would I need anything else other than the calipers, brackets, and dust shields? It's not a V8, so that means the fronts are 316mm rather than the 336mm correct? I know the rears are 308mm regardless.
Thanks!
You shouldn't even need dust shields, I used the factory ones for the 316/308 upgrade on my V70 T5. Just the calipers,carriers and the bolts/clips. Maybe grab the brake lines as well(I just went braided at the time)
Need front calipers and lines, rears with dust shields and lines.
Front steering stop needs to be filled to 14mm as do the caliper mounting ears. Longer bolts are required, iirc M14x60.
Great upgrade, have it on my fwd wagon and it stops better than Rs.
Thanks for the info guys! The plan is to try and pick em up on Thursday after work.
Volvos aren't common here, so I'm hoping it hasn't been pulled yet.
Sent from my SM-N950U using Tapatalk
Bolts for Xc70. I installed calipers with V60 T5 after 2010 . On the back, anchor plates with xc90 are necessary. in S60 I had Xc60 328mm clamps installed.
Wysłane z mojego Redmi Note 5 przy użyciu Tapatalka
1 - 12 of 12 Posts
