1 - 20 of 70 Posts
Banned
Now on sale $64.95
Works on all 94-2012 turbo's
Introducing the Precision turbo control valve from Snabb. Features the fastest most reliable PLC actuators available. Featuring Viton seals for high temperature operation and long life, Stainless fitting components for corrosive environments, and RPTE adjusted precision for the most accurate TCV available. Anodized aluminum fittings and OE connectors with weather pack water tight connections keep this TCV running strong for miles down the road.
Response time:
Opening .002
Closing .002
Want more info on how TCV's affect tuning? Check out our Blog article here: https://ardideas.3dcartstores.com/Boost-Pressure-Variance_b_3.html
Snabb recommends mounting your TCV in a position that minimizes the length of vacuum line connecting it between the turbo compressor cover and the wastegate actuator. For this reason a mounting bracket is not included. Fits 1994-2012 turbocharged Volvo models.
Also Snabb/ARD tunes have the TCV duty cycle linearization map programmed (hence the RPTE adjustment) to match the response speed of our TCV's. One more reason to trust us with all your Volvo tuning needs.
Hmm. No bracket included?
Oh damn it. :(
i just got a new oem tcv lol...:(
Damn I just bought a phuz tcv not to long ago. Would of loved to try this.
Only difference I see so far between the two is the open response time of .006 vs .002
Banned
The main differences:
opening time .002 vs .006
anodized aluminum fittings
longer electrical connector
Also keep in mind that Snabb/ARD tunes have the TCV duty cycle linearization map programmed to match the response speed of our TCV's
thanks!
Banned
Discussion Starter · #13 ·
Thanks for the orders. I'll have more in stock by the end of next week. I have a waiting list up on the site for those who would like to use that to reserve theirs.
Cheers, Kristian
75.00 dollars to the UK...???? pretty please, cant weigh much.:D
our country is CRAP for aftermarket P2 volvo parts..
You know, a SNABB exhaust might be pretty cool. Just sayin' ;)
1 - 20 of 70 Posts
