1 - 2 of 2 Posts
I have a 2002 C70 and it has a small compartment beneath the glove box.
My daughter put her feet in there and next thing you know the whole thing is dangling down, pulled off from the top section holding the glove compartment.
I cant figure out how to fix it.
Any help please?
If the tabs broke off you're going to have to improvise. To get to the screws that mount it, you have to pull the glove box insert out. Open the box, there are about 6-8 screws around the perimeter. Take those out, and pull the box out. The door stays in place.
Then on the bottom you can see the screws that hold that trim up. It's a pretty bad design that relies on tabs which easily break off.
Same problem on driver's side, I put a screw through the side in the door jamb.
1 - 2 of 2 Posts
