signal lights coming on intermittently but not flashing on the right side while the car is sitting no key in the ignition then they will go off by them self.. When they are on I can turn the ignition key on and the left signal lights will work but the right side will not flash even though the flasher is clearly clicking and appears to be working on the dash. Then out of the blue the right side lights will flash and when I remove the key they shut off as they are supposed to. However I could look outside in my driveway 2 hours later and the 3 signal lights on the right side will be back on steady ( not flashing )
Anyone ever had this problem I called a dealer and they said it might be a CEM about $2000 plus time if that's the case might be time to sell it
David White [email protected] 905-356-7706 I have posted before but have had a hard time trying to find and follow up on any replies
