1 - 13 of 13 Posts
I'm experiencing side hop when running over bumps/ small pot holes with one side.
It got
-19" peg replicas with brand new tires (235/35)
-Lowered with Eibachs
-IPD camberbushes
-Superpro front control arm bushes
-Newly realigned and SUM calibrated.
I wonderer if a full Powerflex rear bushing kit will reduce og prevent the side hop?
Sure it won't hurt trying (exept the wallet).
Any other sugestions?
I have the same problem but it's my shocks check those first that's what fixed my problem
Sent from my Epic 4G Touch!
I think they are fine, but I will check again. Thanks!
Edit: They checked the dampers (damper dyno) when I had the car in for an inspection, and they didn't find anything unusual.
did you check tire pressure/alignment ?
Tell dealer, software download iirc.
And the Ultra racing rear lower chassis brace from Viva..
Rear toe to 0 plus upper and lower rear chassis braces fixed mine even under very harder cornering. I used Ultra Racing rear tower braces and custom made the lower frame bracing. I didn't like the clearance on the Ultra Racing lowers though they worked perfectly.
Discussion Starter · #13 ·
I will check the toe, but I'm pretty sure it's close to 0. I will also check the tire pressure. Thanks.
1 - 13 of 13 Posts
