1 - 20 of 230 Posts
Hello folks, I have a new problem with my R, and was hoping someone could help. In any gear, and at any speed, the R will shudder once boost climbs. It's ok if Im very gentle on the throttle, or if RPMs are so low that its not making that much boost. But, once revs rise and it starts making boost (i'd say no more than 1/2 boost) it will shudder/stutter very badly. No codes & no smoke, so I'm pretty sure it's not a coil or plug, because I should get a "misfire on cylinder x" if that were the case (I think). So, being that there is no CEL, could this be the fuel pressure sensor? Would that sensor not throw a code if it was bad? <p>2004, 77k miles, fuel pressure sensor recall was done years ago, by previous owner.<p>tia,<br>Joe<p>
Could be the FPS. Mines failed twice in 12k.... go Volvo! <p>(misfire code only 1 of the 2 times, and only after months of misdiagnosing. So a code is not required for this to be the problem.)<p><br>
Re: Shudder/stutter under boost (xman03)
IPD HD TCV already installed. This problem started after a high-speed run. I will swap in my factory tcv tonight, but I would imagine the IPD unit (if working properly, and it has been) should be ok... <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> <p>This is a very dramatic stutter. but, I was getting a hiccup in the powerband since last week. I tried to adjust the wastegate rod, and the lock nut had come loose and the rod readjusted itself to 0 psi. I thought I had that fixed, but like I said, then I started noticing a single hiccup under accel. So, if the FPS would def throw a code, and the tcv is good (will confirm tonight), what could this be? <p>:: edit :: So the FPS might *not* throw a code? Anybody have the part# handy for the FPS?
Re: Shudder/stutter under boost (Denis)
Thanks, I will def give it a good once over after work today. I'm very interested in the FPS though, anybody know tha part#?
Re: Shudder/stutter under boost (JoeLvo)
someone feel free to correct me, but the CEL will only come on if you have emission related problems, there are myriad other codes that could be stored, but can only be read by volvo ( or a can enabled OBD reader) <p> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> <p>IMO no CEL =/= no codes
Re: Shudder/stutter under boost (FEO)
Ok, good point FEO. <p>Knowing that a failed FPS will cause this type of issue, I think I'm willing to throw this one part at it, if everything else is ok (hoses, wastegate rod). Hopefully someone knows the FPS part# because I can't find it by name/description on myswedishparts.
From the TNN/TSB on the fuel pressure sensor recall:<p>SERVICE:<br>Replace the fuel pressure sensor according to the instructions below.<br>Material Quantity Part No.<br>Pressure sensor (engine code 52, 59) 1 30756097 <B>(THIS IS THE ONE)</B><br>Pressure sensor (engine code 61, 64) 1 8699448<p>Cheers,<p>J<p>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>FEO</b> »</i></TD></TR><TR><TD CLASS="quote">someone feel free to correct me, but the CEL will only come on if you have emission related problems, there are myriad other codes that could be stored, but can only be read by volvo ( or a can enabled OBD reader) <p> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> <p>IMO no CEL =/= no codes</TD></TR></TABLE><br>Correct, emissions level increases of 1.5 times allowable emissions are supposed to illuminate the CEL by OBDII standards. Also the CEL illumination can very depending on manufacture discretion as to what it is monitoring or what "they" want in addition to the emission thing. <p>But many issues can happen w/o a CEL. Live Data and knowing how to read it, is your friend.
Ill will amend my above statement:<p>Its failed twice, I got a CEL once (after misdiagnosing a few times). The second time, no CEL. <p>BOTH TIMES HAD CODES which required a dealer read, not CEL's.<p><br>Double check everything you've touched recently. Since you've been tweaking, its likely something's probably loose not broken....
Re: (JoeLvo)
If you can, stop by a dealer and have your DTCs read. Might shine some light.
Discussion Starter · #15 ·
Re: (S60R1)
I would actually love to do that, but I cringe at the thought of having to drop my car off and be without wheels for days while they get around to it. I will see if a local dealership will do it when I bring it in, and not have me "leave it with them". Wish we could read codes without the dealer.
Discussion Starter · #16 ·
Re: (JoeLvo)
Another SS member lives nearby and has the IPD diagnostic tool <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"><p>I will be scanning the R tonight to see what, if anything, has been stored. I can't believe Volvo wants $220 for the FPS <IMG NAME="icon" SRC="http://www.vwvortex.com/zeroforum_graphics/screwy.gif" BORDER="0">
I had a VERY similar problem when i bought my R it had 83k miles on it and it would do what you are saying no CEL and it was plugs that were just BURNT up i would give them a check you may be surprised i was and i have been a volvo tech for 4 years
Discussion Starter · #19 ·
Re: (SHIFT_S60R)
I just recently replaced my plugs (within 5000 miles) with OEM plugs. I checked the gap and they were all correct (forgot the spec now). *BUT* I did not use a torque wrench when tightening the plugs. I have to say, the R ran like a champ after the plug change. I'm sure that doesn't mean much, but it ran perfectly fine until Saturday night (Upon restarting Sunday morning, I noticed the shudder). In deference to forum rules, I will just say that Saturday night involved high RPM in 6th gear, for a somewhat extended period of time. I will check the plugs, and do them right this time (I was spending $$ on OEM parts at the time to try to cure cylinder misfires, and just couldn't swing the $ for a torque wrench worth owning, obviously a lapse in judgment).<p>So, Stoyan (EAX) was kind enough to plug in his data-logger, and go for a drive with me. I have quite a bit of data that I am graphing up now, and will post. Stoyan, looks like we're going to have a spark-plug party <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/cool.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/embeer.gif" BORDER="0"> <p>Thanks for the continued input <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
^^ Also be sure to check all of your groud wires under the spark plug cover and make sure that non eof them are pinched
1 - 20 of 230 Posts
