1 - 13 of 13 Posts
I've asked a similar question before, so forgive me for bringing it up again. But I read other posts that talk about owners hearing turbo noise, wastegates, etc. So why don't I?<p>On WOT I hear an engine. Nothing else. No whine, no wastegate. Nothing. <p>Is there a chance my turbo isn't actually doing what it should? Or does a stock T5 simply not make any kind of turbo noise?<p>2nd thing. I'm getting hesitation on acceleration. Not brutal, but definitely noticable. Both under hard and soft acceleration. It hits at exactly 2500 rpm. Any ideas what might cause that? <p>Thanks folks.
You should be able to hear your turbo spool but its nothing crazy... If you want to hear it better i would say remove front bumper and right behind where the grille is plastic piece u can remove right behind the left side horn . Its just 2 screws holding in a piece of plastic that looks like a half pipe .... You should be able to hear your turbo spool alot more... Volvo or should i say Ford put in there to make the turbo quiet
Re: Shouldn't I hear a little turbo noise (voegelin)
I know very little but I do know I can hear my turbo on my stock T5... So can my friends when I'm zooming up behind them <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
Re: Shouldn't I hear a little turbo noise (hektikV50)
See, I don't get that. No noise like that at all. <p>Should I take it to the dealer for a check, or is this something any mechanic can diagnose?
I wouldn't take my car to the stealership for a problem like this nor would I take my Volvo to "any" mechanic... Check around for a Volvo Specialist, ask around on here too, I think someone else is from your neck o' the woods.
Re: (jdsr917)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>jdsr917</b> »</i></TD></TR><TR><TD CLASS="quote">You should be able to hear your turbo spool but its nothing crazy... If you want to hear it better i would say remove front bumper and right behind where the grille is plastic piece u can remove right behind the left side horn . Its just 2 screws holding in a piece of plastic that looks like a half pipe .... You should be able to hear your turbo spool alot more... Volvo or should i say Ford put in there to make the turbo quiet </TD></TR></TABLE><br>has anyone else done this. i never heard of it before.
my turbo is very loud actually and everything is stock which surprised me, in second and third gear i have a nice loud hiss sounds from 2000 rpm to around 4000. <br>love the sound though
Try removing the hood liner - it's a 5-10 minute job with no tools required, and made my turbo noise louder. If you want to put it back in, that's a quick job, too.
Is your air filter dirty? Try a new filter. Also remove the "snorkel", that should do the trick but that'll let hot air in.<p>Or get a K&N Intake <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
Re: (kpsingh0)
<br><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>kpsingh0</b> »</i></TD></TR><TR><TD CLASS="quote"><br>has anyone else done this. i never heard of it before.</TD></TR></TABLE><p>I have done it and its amazing sounds about 1/2 to 3/4 as loud as my cone ..... But i seem to have one of the loudest T5's i have heard when it comes to turbo(without cone) <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0"> <p>
I can barely hear my turbo whine. I think it's on the right side (it's been years since I've looked at my engine). The easiest way for me to tell was to go through a construction zone with the concrete barricade walls and roll down the windows. Drop it into a lower gear or give it a little gas (assuming it's safe!). That's when I really notice mine.
Air-Tube - Silencer - Removed & K & N , and Air Horn on Top of ECU - Shorten Up .8750 to Flow More Air - Can Here Turbo , but Our Turbo is Not a High Pressure - High RPM - Turbo - so Turbo Sound is Muted .<p>On a PPC Tuned Motor the Turbo does Sound Better .<p>2. Question : From When the Motor Makes Enough Rpm to Get the Turbo High Enough - to Replace Pumping Looses - and The Variable Cams are Kicking In - all that will Feel Like a Hesitation . It's Been a Long Time Since I Tried<br>The 12 PSI PPC Tune from the Stock 8.7 - 9.1 PSI , but It Seems to Me that the Tune took a lot of that away.<p>It Feels Like Front of Car is doing a - Nose Over , is that what You are Referring to ? - or a Power Bleed ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>voegelin</b> »</i></TD></TR><TR><TD CLASS="quote">On WOT I hear an engine. Nothing else. No whine, no wastegate. Nothing. </TD></TR></TABLE><br>Our turbo is small and spins up early. At WOT, it's been spinning full speed and the engine is howling way louder. So don't expect to hear it.<p>I hear mine quite clearly at 1500rpm, when just tipping into the throttle. Zzzzinggg it comes right on and almost disappears as the torque comes up.<p>In other words, it's subtle. Pay attention and don't expect it to shout to say it's working.<p>Tom.
1 - 13 of 13 Posts
