1 - 20 of 32 Posts
Anybody has any ideas on how to improve our shifters(mt)?
The gate seems perfect, but the throws are just too long....so I was thinking about modifying the selector lever on the tranny itself to reduce the throw, but not sure if there's anything to work with(the lever seems pretty short already)..or
...diy my own short shifter and reduce the throw and gate as well.
Any thoughts?
p.s. anybody know the part# for the shifter?
Can make a cheap "fake me out" by just cutting the down the existing shifter. Its 2inches too high for me as is. Of course, not the best method.
Re: (imageomega)
Quote, originally posted by imageomega »
Actually that is a pretty good method.
Re: (Needsdecaf)
I have cut down about 1' - 1.5' when I installed my Momo Shifter, Its a huge difference, postive difference http://********************/smile/emthup.gif
I willl have a P2R shifter next week ...
Group buy ? And I can check on getting actuall Short Shifters made
wow, I was only half serious.
This gives good results? I would love to do this, was just afraid....
Were you still able to put a knob on it with the stock "post" thing? Would the stock knob still fit on after chopping it down? If so, I'm doing this like now.
Hmm, what about measuring from the top of the stick to the post, taking it down 2 inches and getting rid of the post, then drilling a hole lower and inserting something for a new post?
Maybe 2 inches is too much but the general idea is to keep it as is, just lower.
Re: (mpdbrown)
Quote, originally posted by mpdbrown »
pictures?
there u go
If I got the Short shifter made you would be able to put a stock knob on it .....
but not sure why you would want to .
granted I have the stock knob on both of my cars right now 98V70RM and 98C70T5M but thats just due to being the only one .
But ? if you wanted sure
Im not against an aftermarket knob, just not sure its worth the money for anything I like. I did a lot of looking, only things which suited me were over $100.... just hard to pull the trigger.
Once I figure out what I like I will just get the machine shop to make me it for like $20 lol
Discussion Starter · #15 ·
Re: (Chilled Man)
Quote, originally posted by Chilled Man »
that would be awesome http://********************/smile/emthup.gif
let me know if you find any good deals on a used shifter...wanna take a crack at making my own....which brings me to my next ?
Is there enough room below to extend the rod a bit? or does the pivot point gonna have to move up a bit?
Lowering the top of the shift rod just makes you put more effort into the shift, and does nothing for throw/engagement.
Re: (JoshV70_)
Quote, originally posted by JoshV70_ »
That being said what will ?
Extending both at the bottom the same lenght or ?
Re: (JoshV70_)
Yeah, exactly, you have to reduce the angle of the shift to have shorter throws. I mean, you may feel a difference when you change the length, but the angle still is the same.
Anyway. There has to be someone out there that can make a short throw shifter for the S60. I mean, there is a pretty good market for it.
Re: (Chilled Man)
Move the cables at the attachment points on the gearbox closer to the pivot points.
Re: (JoshV70_)
So bascily in simple terms cut the rods on the bottom shorter ?
1 - 20 of 32 Posts
