When downshifting to engine brake, apply a little throttle to avoid jerking the car. You'll know when you get it, should be smooth. When shifting up, ease off a bit unless you're already really into the throttle at high RPM's. Hope this helps.For any one who has an automatic S60 R with an automatic transmission, when using the tiptronick should you push the gas or let up like on a manual transmission?
