1 - 2 of 2 Posts
I just got the 2012 XC60 3.2L 6 speed AT recently. I noticed sometimes the car makes a clunk noise when I shifted from R to D or from N to D. it doesn't happen every time. Sometimes it's smooth and no noise. It happened randomly and on level ground or incline/decline.
While driving, the low gear shifting is slightly not smooth. High gear shifting are very smooth.
Can this be the some gear tooth were wore out in the transmission? Or the transmission fluid is too old and need changing? The car has 125k miles on it. I suspect the fluid was never changed.
Thanks
Mine does the same at the moment, but I believe it is due to worn CV joints (axles). Do you hear any other noise or clicking when under full turn to right or left (which I also hear sporadically)?
1 - 2 of 2 Posts
