1 - 10 of 10 Posts
I'm so bummed out. A CD is stuck in my R's CD player and Volvo service says that it has to be sent out for replacement. They say it's likely a circuitry problem that's somewhat common on Rs that have Sirius (my '04 does not). <p>It'll cost up to $600 for a replacement unit, I'm out of work and the extended warranty ran out 12 days ago. <p>Any ideas as to what I might do?
Re: Sheesh. CD is stuck in player -- twelve days after warranty ran out. Ideas? (JimiRayClapton)
<A HREF="http://forums.swedespeed.com/zerothread?id=97025" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=97025</A><br><A HREF="http://forums.swedespeed.com/zerothread?id=114883" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=114883</A><p>you can try that, it's free after all<p>gluck
Re: Sheesh. CD is stuck in player -- twelve days after warranty ran out. Ideas? (FEO)
press eject - while you hear the changer trying to work, slide a different CD into the unit about halfway - then back out again. <p>Works like a charm everytime.
Re: Sheesh. CD is stuck in player -- twelve days after warranty ran out. Ideas? (lan)
It worked!<br>You guys are amazing mofos! Gonna tell Volvo of Westport service about this. And charge them for this valuable piece of info.<p>Thanks. JRC
140$ on ebay, if its really done
Glad you got it out!<br>For what it is worth, the CD changer knows nothing about the existence of Sirius.
Re: Sheesh. CD is stuck in player -- twelve days after warranty ran out. Ideas? (rogersampson)
Actually, Roger, they said the problem is attributable to water leaking in at the site of the antenna on the roof which which causes problems at the radio/CD player inside the car. <br>Just reporting what they said they've seen several times already.<p>Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>lan</b> »</i></TD></TR><TR><TD CLASS="quote">press eject - while you hear the changer trying to work, slide a different CD into the unit about halfway - then back out again. <p>Works like a charm everytime.</TD></TR></TABLE> <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <p>This always works for me too.
Re: Sheesh. CD is stuck in player -- twelve days after warranty ran out. Ideas? (Bdubs)
I've tried changing to FM, and then back to CD. worked fine. oh yeah, and that was a day in negative degrees.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JimiRayClapton</b> »</i></TD></TR><TR><TD CLASS="quote">Actually, Roger, they said the problem is attributable to water leaking in at the site of the antenna on the roof which which causes problems at the radio/CD player inside the car. <br>Just reporting what they said they've seen several times already.<p>Thanks</TD></TR></TABLE><p>Hard to imagine, but these are factory trained professionals, so who knows! If there is water ingress, and it is finding its way into the underdash wiring, I would be worried about more than the head unit!<p>Glad to hear you do not have one of these dealer installs!
1 - 10 of 10 Posts
