Hi all,
I have a 2006 V70R 6speed manual transmission vehicle with about 163,000 miles. In Oct 2011, it was determined I had a sticking front caliper, so it was replaced with a used unit with 60,000 miles on it. Front rotors were replaced (1 OEM, 1 nonOEM) and brake pads (not OEM). The non OEM stuff was supplied gratis from the dealer I bought the car from in Vermont. The mechanics that worked on the car failed to make strong recommendations against non-OEM pads, which is why I think the rotors were glazed by January. Around that time, I started getting a pronounced wheel shake. I took the car in to another mechanic, and they told me the front rotors were blue and needed to be replaced. OEM rotors and pads were replaced. They also said a lower control arm needed to be replaced. They said to do the brakes first, then the control arm, if the shaking was still present.
I picked up the car, and the wheel shake when braking was less pronounced, but I believe it wasn't obvious because I wasn't braking hard during the warm-up/break-in period for the brakes.
It's early May, and about a month, 1200+ miles and after doing an $700 brake job, I have a wheel shake again. What do you think it can be? Is it that control arm? Do I have warped rotors due to defect, or from the other 163,000 (original) caliper? Are the rotors warping because I have a sloppy control arm? Or, am I just braking too hard? What causes wheel shake in the steering wheel like this?
Also, I am replacing all four tires because today, when I went for an inspection, you could see the wheels were peeling on the inside. I'll also be getting an alignment.
Thanks in advance for any tips or suggestions. I'm happy to answer any questions that might help solve the mystery.
Hunter
Hunter
